use a straight flute brazed carbide bit with a bearing on the end. let the bearing ride on the finished surface, and the bit will remove what's left of the tabs.
Get a bit smaller than your part's smallest inner diameter to make sure the bit will reach all areas you need, or make sure the tabs are accessible with the bit you choose.
