Share Your Files Part or Art - Page 582
Page 582 of 586 FirstFirst ... 82482532572579580581582583584585 ... LastLast
Results 11,621 to 11,640 of 11709
Thread: Share Your Files Part or Art
  1. #11621
    Jan 2012
    Default Re: Share Your Files Part or Art
    Quote Originally Posted by space670 View Post
    Can you find a picture of something you had in mind?
    Its a little hard to make something when we do not have any general idea what you are looking for.
    Try search for "drawing worn out boot or shoe" and find a picture.
    looking for something like this
  2. #11622
    Member ronald44181000's Avatar
    Sep 2008
    Quote Originally Posted by rmachinist View Post
    Thanks Ronald
    Your Welcome.
  3. #11623
    Member space670's Avatar
    Dec 2010
    Norway
    Here you are
    Attached Thumbnails Attached Thumbnails Share Your Files    Part or Art-00cdfc929800d1e8f12f10e2a8b8aa41_worn-clipart_612-549-jpg
    Attached Files Attached Files
    CNC 6040 Router Engraver Drilling and Milling Machine / Anycubic Photon Resin 3D Printer 500x600 mm laser cutter/engraver 2500 mW
  4. #11624
    Jan 2012
    Here you are
    space670 WOW you are Great! may i ask how you did this? Thanks for helping me out
  5. #11625
    Dec 2010
    Norway
    Your welcome, happy to help.
    Have a look at post number #11591 further down in the thread.
    There I have explaind it a little.
    You use Inkscape
  6. #11626
    Jan 2012
    You use Inkscape
    Thanks you help me out alot!!! Gold Star for You!
  7. #11627
    Sep 2009
    Downloadable clip-art for May events such as Mother's Day, Memorial Day, Cinco De Mayo and We are open curbside pick-up only sign.
    Comes in different file types that you can import into your CNC software.
    Attachment 441756
    You can download the clip-art graphics at the file at link below.
    https://www.visionengravers.com/supp...-download.html
  8. #11628
    Dec 2010
    Norway
    Here is a DXF of a Giraffe if any are interested Share Your Files    Part or Art-giraff_01_dxf-jpg
  9. #11629
    Nov 2007
    U.S.
    Does anyone happen to have a dxf file of a 1979 ford boss mustang, for cutting on laser?
  10. #11630
    Dec 2012
    Mexico
    Hello.
    It is possible to get some designs googling for free patterns for hand quilting and embroidery.
    I´m sure you´ll get some good ideas from them. The included picture shows a simple design.
    In many cases you can get some form of file like SVG, DXF or others but it is possible to translate among them. It´s even possible to use programs like INKSCAPE to turn a JPG file into an SVG and then into a DXF file.
    Regards.
    Attached Thumbnails Attached Thumbnails Share Your Files    Part or Art-sample-01-jpg
  11. #11631
    Member jalessi's Avatar
    Feb 2007
    Question Re: Share Your Files Part or Art
    Quote Originally Posted by ryke View Post
    Ryke,
    Did you mean 1969 Boss Mustang? Please confirm year.
    Have a most awesome evening!
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  12. #11632
    Dec 2012
    Mexico
    Hello.
    Given the appropriate distances a mill, an engraver or a laser cutter are just about the same thing as a quilter the only real difference being the tool.
    I see no reason why a pattern done for a quilter cannot be done on any of the aforementioned machines. Of course some code translation may be required but since it is possible to translate almost all quilting codes into dxf format that should not be a big issue.
    I think it´s worth looking at the following web page.
    https://www.etsy.com/mx/market/mustang_embroidery
    Regards.
    PS: in a laser engraver coloring can be changed for shading with a final result as watching a color image in a B/W monitor.
  13. #11633
    Dec 2010
    Norway
    Picture of what you are looking for?
  14. #11634
    Nov 2007
    U.S.
    Share Your Files    Part or Art-boss429slide3-jpg
    1970 not 79 lol
    Attached Thumbnails Attached Thumbnails Share Your Files    Part or Art-pic-mustang-jpg
  15. #11635
    Dec 2012
    Mexico
    1970 not 79 lol
    Hello.
    This is just to give you an idea of the complexities of the conversion process. To avoid confusion I´m adding again the JPG file.
    I suggest you try this one out just to check that your machine is compatible with the format.
    While the conversion process from JPG to NGC is strightforward it takes quite some time as the conversion generates a miriad of small straight lines to do all the contouring. If fact that information is more of a NC nature than that of a CNC but is about the only way to do it, at least as far as I know.
    I had to scale the original file to about 25% as the converted file was nearly 8 times this size.
    I´d also expect the machining time to be rather long.
    If your machne is compatible try getting an image similar to the one I added and post it. I´ll try to get the conversion for you.
    Regards.
    Attached Thumbnails Attached Thumbnails Share Your Files    Part or Art-mustang-jpg
  16. #11636
    Dec 2010
    Norway
    Here are 2 different ones, hope you can use any.
    Do show pictures of the finished piece if you can.
  17. #11637
    Nov 2007
    U.S.
    Sorry for delay, here is the fire pit I made with the Mustang
    thanks for all the help
    Attached Thumbnails Attached Thumbnails Share Your Files    Part or Art-resized952020072395160516951536-jpg   Share Your Files    Part or Art-resized952020072395152831956699-jpg
  18. #11638
    Dec 2010
    Norway
    Looks nice
  19. #11639
    Jan 2012
    looks good
  20. #11640
    Member Bigbird48's Avatar
    Nov 2012
    can anyone help make a vector of the picture on the left side Share Your Files    Part or Art-operation-freedom-bird-logo-jpg
