Acme is 29°.Originally Posted by Geof
isn't it imperial messurement? so wouldn't it be imperial machinist not, American machinist? Wait! does that make us Imperialist?
Damn i guess all those old movies are right! We are imperialist pigs!
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
UCCNC 2017 Screenset
I don't try to decipher what the speaker is saying. I just smile and nod. Then I refer to the drawing for specifications.
I come in contact with "Designers" who imagine pretty things in their heads but can't communicate their needs.
The big rule I have is: No drawing in the air with your fingers.
The client is responsible for supplying valid CAD drawings via email. If they can't handle that, I can't do business with them.
I had a designer in my shop who wanted to sketch his idea on the shop floor with chalk, which was what he did post-war as a glass designer in W. Virginia. I told him it was 2003, not 1953. He looked confused until I spelled it out.
Your talking crazy man!Everything in writing
whered that come from, and I am glad you got that off of your chest!
thanks
Michael T.
Yeah; I guess if I pick up mistakes made by other people I should hang my head in shame; consider it done!Originally Posted by ger21
Being relative to what?Originally Posted by cadman
.1 is a tenth of an inch
.0001 is a tenth of a thousandth.
Machinists are more concerned with thousandths than they are about inches.
Just like being in a car, when someone says it's a tenth up the road, I think it is pretty safe to assume they are not talking about a tenth of an inch :-)
When you say a "tenth" to a non-machinist and ask them to write it down on paper, nine times out of ten it will be .100, just the way the old high school math teacher taught. Say "tenth" in most machine shops (non metric shops) and it is understood to be .0001. Its been quite a few years since I've heard someone say "one ten thousandth"
People outside of manufacturing will rarely, if ever, run into a unit of measurement smaller than .100, with exceptions like mechanics, people with home shops, etc... . For those people a "tenth" as in .100 is as small as it gets.
.100 = hundred thou
.010 = ten thou
.001 = one thou
.0001 = one tenth
.00001 = 10 millionths
.000001 = 1 millionth
At least thats what I am used to, the super precision lathe I run at work has resolution to 10 millionths. I know when you put it in jog mode and select .00001 for res you can spin the dial all day long and it seems like the thing never moves.
JP
I think ChrisD hit it right when he wrote it's just slang.Originally Posted by miljnor
Using vernacular within a shop can/might work when all the employees are on the same page. Communication between organizations should not include assumptions.
I know my life is easier when I make the client spell it out on the drawing. I don't care what a "tenth" is. I can't even get my dealer to tell me what an "eighth" is. Is is gross and include the ziplock or is it tare? It never seems to come out to my advantage.
"0.0001" I understand.
I know what you ment
I was just razzing you because the post was somewhat off (do to the other posts lack of "customer input" in the discussion)
just couldn't resist.
no hard feelings (hopefully)
thanks
Michael T.
Hello,
Is it correct to say 15 tenths is 0.00015" ?
Thanks.
calling .0001 a tenth is common shop floor talk/slang and it's just a given , .0002 is two tenths . One tenth of an inch is not a reference we would normally use , it would be a hundred thou (unless the drawing showed dimensions in fractions vs decimal)
Outside of machining a guy would say one tenth thousands of an inch because people will naturally view one tenth as 1/10th
When using the Imperial system of measurement and in the machine shop, the basic unit of measurement normally is 0.001'' (thou or thousandth). So 0.100 would be spoken (in machine shop speak) as 100 thou. A spoken tenth would be 0.0001'', or a tenth of a thousandth.
Jim Dawson
Sandy, Oregon, USA
