Countersink Depth Chart
Results 1 to 6 of 6
Thread: Countersink Depth Chart
    Sep 2007
    Default Countersink Depth Chart
    Awhile back I found a chart that told you how deep to run a countersink to obtain a fixed diameter. I can't seem to find where I found it and I can't find my printout of it. I know there are calculator programs that you can buy, but this was a really cool chart. It had all dimensions for 82', 90' and 100' countersinks. Does anybody know where to find something like this?
    Sep 2008
    I can compose an Excel spreadsheet for this if you're interested. I can't do it overnight however. As I get older I get slower. If you want it, I'll do it. Let me know.
    Gene
    Registered Curley's Avatar
    Feb 2010
    Default Countersink Depth Calculator
    Here is a calculator that solves for depth: http://janproducts.com/countersink_calculator.html
    Moderator wms's Avatar
    Mar 2003
    Drill Point Angle >>>> Factor
    (60 degree)>>> .866 x Dia = Point Depth
    (82 degree)>>> .575 x Dia = Point Depth
    (90 degree)>>> .500 x Dia = Point Depth
    (118 degree)>> .300 x Dia = Point Depth
    (120 degree)>> .388 x Dia = Point Depth
    (135 degree)>> .207 x Dia = Point Depth
    Dia is hole chamfer diameter, not tool diameter.
    Point depth is how deep to drill to get the desired chamfer diameter with that drill point angle.
    Dec 2015
    Default Re: Countersink Depth Chart
    Ok,
    so if my diameter of my countersink of the material is .75 of 82 degrees, im going to take .575x75=.43125 for depth. isnt that a little bit to much...should i take that awnser .43125/2=.215625
    Registered deputydawg's Avatar
    Oct 2013
    Erie, PA, USA
    90 degrees would be .375" deep. You'd have to go deeper with an 82 degree, so .43125" is the answer you're looking for.
