Newbie How does water cut things but it is so soft. Mohs question.
Results 1 to 7 of 7
Thread: How does water cut things but it is so soft. Mohs question.
    Member ballsystemlord's Avatar
    Sep 2021
    Georgia
    Cool How does water cut things but it is so soft. Mohs question.
    Hello,
    So I've been thinking about how you can scratch glass with diamond, but you can't scratch it with water. Yet, water, over time, wears through rocks.
    So, how does mohs work exactly in such instances? Can you cut harder materials with softer ones? I'm certain I'm missing something here.
    Thanks!
    Member Kenny Duval's Avatar
    Jan 2013
    United Stated
    Default Re: How does water cut things but it is so soft. Mohs question.
    Becasue the water is carrying contaminates. It's not entirely the water doing the work. The minerals it carries, its abilitiy to be a solvent and the forces created as it flows over or around something wears away at the softer material. In the case of a waterjet the high pressure combined with the garnet media being transported in the stream does the cutting.
    Sep 2021
    Georgia
    So how does the force (mass * acceleration) affect the cutting capability exactly? Yes, I'm asking about the math.
    Jan 2013
    United Stated
    You don't want this particular dummy trying to explain the math.
    Sep 2021
    Georgia
    Community Moderator RaderSidetrack's Avatar
    Apr 2018
    East Tennessee
    If you really want to see the math behind waterjet cutting, see this paper:
    https://www.mathsci.udel.edu/content...with_Water.pdf
  7. #7
    Sep 2021
    Georgia
    Quote Originally Posted by RaderSidetrack View Post
    That's cool, but I wasn't asking so much about waterjet cutting as about how force affects cutting with respect to the material used to do the cutting.
    As in:
    Abrasive-A1 has a mass of B1, moving at C1 speed, with a hardness of E1, and dimensions D1.
    It's cutting through a stationary object (A2) with a mass of B2, a hardness of E2, and dimensions D2 (assume it's square for simplicity).
    To compute the length of time it will take to cut through object A2, you would ....?
    Obviously, you'd get "inf" if it were impossible.
    Last edited by ballsystemlord; 03-16-2022 at 11:31 PM. Reason: Change terms to be more clear.
