PaperStone
Results 1 to 6 of 6
Thread: PaperStone
    cpnagle_cnc's Avatar
    Jan 2021
    Default PaperStone
    I'm fairly new to cnc routing PaperStone. Currently using Vortex Tool #3135 (De Viper) "1/2 Compression bit. It cuts just fine however the PaperStone material is a very strong material and turns out is quite abrasive/hard on tooling. Cutting between 6-8 sheets before the bit becomes dull and needing replacement. Just curious what other peoples experience with PaperStone is and what they use for tooling? Thanks
    Member awerby's Avatar
    Apr 2004
    Default Re: PaperStone
    It's a solid material; ;why are you using a compression bit? That's usually used because you don't want to disrupt the veneers of plywood. An ordinary upcut bit would probably work fine in paperstone. You might try a diamond-coated bit if the abrasion factor is a big issue for you.
    Jan 2021
    Well it is what the company I work for was using to the best of their knowledge before I was hired. I mean the compression bit leaves a clean cut edge. Paperstone in my limited experience with it so far I have noticed it can chip on the edges just a bit, so perhaps that is why they were using a compression bit idk. And yes we just ordered and tried a new (PCD) Diamond Coated Compression bit yesterday, seemed to work great but the key is how long will it last. Thank you for your input Andrew.
    Apr 2004
    Let us know how much cutting you get out of that PCD-coated tool, and how much it cost versus the uncoated version - I know they stay sharp longer, but not if it's really worth the extra cost (if you don't value your time spent changing bits, anyway).
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I've only cut Paperstone once or twice in the past, but if cutting a lot of it, I'd try an Amana DRB-208 or similar.
    I use them when I need to cut a lot of abrasive materials, as they'll last 10x longer than carbide.
    UCCNC 2017 Screenset
    Jan 2021
    The PCD-200 tool only lasted 8 cuts before I started to see cut quality begin to diminish. Soon after I realized we were running that tool way too fast according to manufacturers feed rate recommendations. Gonna try a new bit, same one but at 140ipm, we were running 200-300.
PaperStone
PaperStone
