Need Help! Need help selecting material
Results 1 to 3 of 3
Thread: Need help selecting material
    Member Brain_on_fire's Avatar
    Apr 2019
    Default Need help selecting material
    Hi! I'm a student that needs help with a project. I need help with selecting a material for this piece. I'm using the metric system.
    https://i.imgur.com/kVgwliT.jpg
    This is a table on mini milling lathe. In the task it was only written that material is cast iron so I'm free to choose any that would suit this piece. I've selected EN-GJS-400-15 ductile cast iron tho I'm no expert and I'm open to suggestions perhaps anyone can recommend another material. I need to select workpiece for it. I have an option to cast something like this but since I only need to make 10 pieces I think it would be cheaper to buy from standart cast iron sheets... I don't really understand how I'm supposed to select and buy it. I found something like this:
    https://www.steelexpress.co.uk/cast-...N-GJS-400.html
    It says it comes in round shapes 25mm diameter to 450mm diameter. Is it even possible to make that plate from round piece. Perhaps someone can help me with finding a sheet? I need arround 224x120x26...
    Argh... I'm really clueless at therse things...
    Dec 2013
    Default Re: Need help selecting material
    Cast iron also comes in flat plates. A quick call or email to the vendor would be helpful to get you pointed in the right direction.
    You might also try here Rectangular Plate - Cast Iron - Thickness from 12mm-25mm (WDS 920), Rectangular Plates | WDS
    or here https://www.rapidmetals.co.uk/?portfolio=cast-iron
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2019
    Quote Originally Posted by Jim Dawson View Post
    Thanks for your reply Jim. Yesterday I checked the link you posted from WDS. The thickness is 12-25 mm. From what I understand I need arround 26 mm thickness for my piece as I need to do some milling so I get the right ammount of roughness. I noticed they have another piece with 32 mm thickness:
    Rectangular Plate - Cast Iron - Thickness from 32mm-50mm (WDS 920), Rectangular Plates | WDS
    I'll need to talk with my teacher if it's not too much metal wasted if I take this one (also the dimension L is either 200 mm or 300 mm there, I need about 224 for mine). If it fails I guess I'll have to email one of the suppliers as you suggested.
    I'm always open If anyone has any other suggestions
    Banned
    Jul 2019
    You want a few steels, I think you can find Songshun steel. Their products are not only of high quality but also affordable.
    Contact: https://steelpurchase.com/about/
