- Need Help!- Newbie need help in pvc cutting
Re: Newbie need help in pvc cutting
I think you are trying to cut too fast.
With a small diameter tool you need to spin it fast. I think 18000 rpm is right.
The surface speed:
S (m/min) = PI x Diameter (m) x rpm
=3.14 X 0.003 x 18000
=169.6 m/min which sounds about right for plastic.
The chipload:
T (mm per tooth per rev)= 600 (mm/min) / rpm
=0.033 mm per tooth per rev
For small diameter tools, I use down to 0.4mm endmills I allow 1% of the diameter as chipload. With larger and stronger tools you might allow 2-3%.
Lets do the calculation for a 2% chipload:
T (mm)= 0.02 x Diameter (mm)
= 0.02 x 3
= 0.06 mm
So your chipload is close to correct at a federate of 600mm/min. I think you are going to have to take two or three cuts to get through it,
3mm tools are fairly weak. Either that or slow the feedrate down until you don't overload it, maybe 200-300mm/min.
Craig
- You may not post replies
- You may not edit your posts
Forum Rules
