I have a bunch of g-code files that are formatted in Inches. I run them on Mach3.
I'd like to join a co-op that uses a Laguna machine. It seems to be set up for MM.
I did a quick test and renamed a .nc file to .mmg. After some fussing with the origin, we did get it to run, but it barely moved the cutter.
So afterward, it looks like the machine is set for mm.
Is there a setting to just tell it to run in inches?
I have a program that I could use to convert my files, but that would take a long time to do them all.
Any ideas?
Chris
Hmmm. I think I have that. So the beginning of my code is:
N10 G20
N20 G0 G17 G40 G49 G80 G90
N30 G64
N40 (first body - ZERO Xtra deep pocket)
N70 S10000 M03
N80 G01 X20.5963 Y11.8868 Z0.25 f50.0
N90 G01 Z-0.2275
The beginning of a sample from the shop is:
(Filename: V-Carve 1)
N10M03S16000
N20G00X-23.524Y-54.217Z5.080
N30G1Z-5.080F508.0
N40G1X-23.040F1270.0
N50G1Y23.289
N60G2X-20.107Y26.222I2.933J0.000
N70G1X5.525
I thought that S16000 was the speed, but 1600 would be more like 65 inches, which is in the range. But this is 650 inches. So maybe something else is up?
S16000 is the RPM.
Use find and replace to change all the F commands, which are the feedrates. Multiply them by 25.4.
However, depending onthe type of Laguna, it may not support G20/G21. I think the Laguna Swift may be metric only.
UCCNC 2017 Screenset
So if the code I tried with the G20 ran in mm, then I'm probably stuck there.
On my machine, I use a manual switch on the router to set the RPM. So I'll need to add that to each file.
I'll try that, change by feed rates, and convert to mm and see if it works.
Bummer some are metric only. What a pain. I think I have 1,000s of files. I use 25 or so most of the time though.
Look up the spec's for the control to see which codes the control excepts most will do both
If you Program is Witten like above the F would not be recognized, it can not be lower case you have ( f ) for feed, it has to be ( F ) your Feed rate is F50. which is 50IPM
The M3S1600 is your spindle speed
Is the V carve-1 program in inches or for metric, if it is for inches then your feed rate would be way to fast at F508.
Mactec54
The top code works fine in Mach3. That is what I have been using. The bottom is a Laquana compatible example. Good point though if a generic controller like caps.
I see the spindle speed command now. I'll need to add those.
I read the older controllers use G70 for inches. I'll try that.
The info on the controller I was able to get is that it is a "Laguna IQ HHC". I'm not sure on anything Laguana. I know Mach3 well though, at least for what I do.
Mactec54
So I did find out that this machine only runs metric, in mm. I have en editor that I used to convert my code. I can do a "scale" on all 3 axis by 25.4 That seemed to work on the first program. The beginning is posted above. I tested that code, then converted the rest.
So I went back today, and only the first program works. The rest say "out of range" or something like that. I have 8 I need to run to make a guitar.
I checked them in Mach 3 and noticed the next programs still had the G21. I figured the laguana would run metric no matter what but maybe this needs to change to g20 like the first one?
I'm not totally familiar with the Laguana. I'm pretty sure we did a ref-home, then set what mach calls an "offset" to get it in range. Then the next programs should have been aligned with each other.
It is an hour commute to this place, so I'd like to have more than one thing to try.
Any ideas?
I run an inch post on my Laguna IQ and it works fine. All you need to do is change the post to call Feed rates in metric..
N2 (Filename: .236 Rough)
N3 (Saturday August 04 2018 08:01 AM)
N4 (Machine: Laguna IQ HHC)
N5 (Material Size)
N6 (X= 24.000, Y= 12.000, Z= 0.260)
N7 (.236 End Mill)
N8 G90
N9 G20
N10 G00 Z2.000
N11 M03 S18000
N12 G00 X3.459 Y4.438
N13 Z0.100
N14 G01 Z-0.060 F1270.0
N15 X3.387 Y4.455 F1524.0
N16 X3.364 Y4.417
N17 X3.459 Y4.438
N18 X3.478 Y4.530
N19 X3.413 Y4.545
N20 X3.342 Y4.565
N21 X3.174 Y4.277
N22 X4.133 Y4.494
N23 X4.082 Y4.489
I was helping a Laguna user recently, and found out that it would run G0 and G1 moves in inches, but not G2/G3 moves. It seems to autodetect inch units and work properly, but not with arcs.
