- Depth of Cut and Flute Length
If my endmill has say a 0.5" flute and I'm cutting 0.1" depth of cut per pass, is it ok to go as deep as say 1" since the top half is already cut?
Re: Depth of Cut and Flute Length
You can, as long as the flute dia. is the same as the shank dia. and you don't do a finish pass at full depth. fyi, Some software adds the finish pass automatically in the roughing cycle.
I just learned about finishing passes today, never used them before. Makes sense.
- You may not post replies
- You may not edit your posts
Forum Rules
