Newbie Mitre fold realy thick board
Results 1 to 2 of 2
Thread: Mitre fold realy thick board
    Registered tricud's Avatar
    Nov 2017
    Croatia
    Default Mitre fold realy thick board
    I have need to cut miter fold v groove in 38 mm (1"1/2) thick mdf with melamine outer layer. Reality is that I have CNC with 1.5 kw spindle (ER16 collete) and no room in shop for router table. Existing bits for that large profile are all 1/2 shank size and best I can find for 1/4 shank size is 3/4" or so in depth. So I was thinking to make multiple passes with smaller v bit to achieve same effect. As a newbie I made strategy with 6 passes (see attachment) but I'm not sure is that manageable in real situation and where are pit falls. Or are there some other methods?
    Attached Thumbnails Attached Thumbnails Mitre fold realy thick board-v_bit1-jpg
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Mitre fold realy thick board
    That method should work fine.
    But I've always found miterfolding with a router bit to be problematic, as it's difficult to get a consistent thickness, and a clean cut at the tip. Melamine and laminates always seem to chip a little. I have much better results when miter folding veneered panels.
    UCCNC 2017 Screenset
