- Need Help!- Machining ASTM-B196 C17200 Copper
Hey All- So I'm bidding a job that contains machining the above listed Copper. I've never machined any copper and thought I would get some opinions on it? does it machine like Aluminum, Brass? Any tips before I take this job? It's all milling, no turning. Normal machining operations, no crazy features or anything. A couple tolerances on surfaces being +/- .001 but nothing crazy. It's large Qty and will be doing this on our Haas VF2. Any opinions or help would be greatly appreciated!
Thanks!!
-Nate
Activation process
Re: Machining ASTM-B196 C17200 Copper
One of the things to keep in mind when machining beryllium copper alloy c17200 is that the material has exceptional corrosion and erosion resistance and is, therefore, more durable than most other copper alloys on the marketplace today. To get full use from the material, you might consider working with a metal specialist in reviewing the material’s qualities and determining how to integrate the copper alloy into your future projects.
A leading name within the metals industry in the United States is Busby Metals. The company is considered one of the global specialists for supplying beryllium copper alloy c17200 and can provide you with a large quantity of the product within a consolidated timeframe thanks to their immense inventory. Make sure that you contact the trusted team at Busby Metals before moving forward with your project. Their experts can answer your questions and guarantee you’re achieving full value for money and for the time you’ve put into the project.
Call the Busby Metals offices today to discover more about beryllium copper alloy c17200.
- You may not post replies
- You may not edit your posts
Forum Rules
