Wave Pattern in MDF - looking for tool recommendations
Results 1 to 2 of 2
Thread: Wave Pattern in MDF - looking for tool recommendations
    Jan 2011
    Question Wave Pattern in MDF - looking for tool recommendations
    Howdy folks,
    I don't do much with 3D machining. I am working on a project now that has somewhat large panels with a 3D wave/ripple pattern on the surface.
    I am wondering what you guys recommend for endmills for this project, for roughing and finishing. I don't need an ultra smooth surface, as I'll be using a paint that goes on with a bit of texture.
    At its deepest, it is 1/2 below the surface of the 3/4 material. The side panels are 27.75x48.75. I have attached an STL in a zip if it helps.
    I have a 50x102 KRMX-02, with an Hitachi M12VC, and Precise Bits UP collets for up to a 1/2" shank.
    Should I use a large ballnose for this? Tapered ballnose? How big? I want to limit the machine time as much as possible.
    Attachment 260462
    Attachment 260464
    Attached Thumbnails Attached Thumbnails Wave Pattern in MDF - looking for tool recommendations-wave-jpg
    Attached Files Attached Files
    Mar 2003
    Shelby Township
    Default Re: Wave Pattern in MDF - looking for tool recommendations
    I'd use something like a 1" core box bit.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
