Hi all
as I promise I am posting some of our early cutting and engraving using EXLAS 1280 Last cutting and engraving products..
1-Over look to the EXLAS . nicely designed I have to admit.
2-inside motor very nicely fixed & Professional ball screw lifting table with 2 motor drive
3-side reflecting mirror, easy to be alignment.
4-excellent output cutting and engraving wood at very high speed.
5-side door looking to power supply and controller.
6-Clean acrylic cutting.
My over look of the machine and its performance for our work, we are very pleased with the results. Sharp and clean cutting acrylic and wood. Engraving we do need to do some tricks in Photoshop and get excellent result from the EXLAS. For any architect need to do models, I hardly recommended over the EPLOG, it is much easy to handle and faster and cheaper. My advice don’t get 80w power you will not need it , 60 is better for us, we do have plane to get smaller EXLAS 6040 instead of fixing our EPLOG, re filing the 25w laser and getting new mirror and lens will cost us more than 2.5k. adding lettil more than we will get new small EXLAS in office.
Mohammad
