LASER CUTTER BASICS
Page 1 of 3 123 LastLast
Results 1 to 12 of 32
Thread: LASER CUTTER BASICS
    May 2005
    India
    Default LASER CUTTER BASICS
    Hi I am a real novice in this field so i am hoping some can help. Also I hope I am in the right forum.
    Can some one tell me the basics of laser cutting. some of my questions are as follows.
    1. If the laser cuts by cutting through the material then what prevents it from cutting through the board the material is on.
    2. Is there a focussing mechanism. If so does it focus on the top surface or the base plate.
    3. in 3D Laser cutting how dpes the laser only burn out the right depth and not burn through.
    4. it seems that most Laser Cutters move around 1000mm/s. What mechanism is used i.e a lead screw style or what as that is a fast speed compared to CNC.
    Regards fnp
    Registered Litografa's Avatar
    Jul 2008
    Lithuania
    Welcome on board! You will love lasers!
    1) Usually laser can cut SOME materials only. And CAN NOT cut other materials. So if you have chinese laser with CO2 tube - you will be able cut wood, plastic, paper and some other materials BUT you can not cut metals - steel, aluminium and etc. So usually table in laser engraver/cutter is made from aluminium.
    2) Focus is setting based on top of material. Be careful with cutting of thick materials. Usually you will cut this materials in few passes. And if for the first pass you must set focus on top of material, for all other passes you must set focus to the top of material BUT AFTER setting focus manually move table slightly up (depend from how deeply was cut during previous pass/passes)
    3) You couldn't do real 3D on laser (especially on Chinese with glass tube). You will have (I name it) pseudo-3D. Gray scale image will be engraved based on machine's settings POWER/SPEED for each level of grey color. Together with problem that all materials are not homogen final result (depth of engraving in certain place) is difficult to predict.
    4) I am very familar with GCC laser engravers and they have stepper/servo motors and belts for moving laser head.
    May 2005
    India
    Thanks a lot mate, that really helps. but I have a few more questions.
    1. What if the laser cuts through metal then what do you use for a base.
    2.Say I am cutting balsa wood say .5" thick does one pass suffice.
    3.Is the focussing of the laser manual or automatic.
    4.is the laser focussed by moving a lens apparatus or moving it along the z axis.
    5.If lasers dont do 3D then what do these 5axis machines do.
    6.Also say if you are looking to make wood mold would you then suggest a cnc router for that and a laser for cutting. are there cnc machines where you can change the cutting head betweena router and a laser.
    Regards,
    fnp
    Jul 2008
    Lithuania
    In this case manufacturers use steel and make special cutting tables - looks like honeycombs or like set of linears. During cutting some parts of this table will be damaged. Best way to prevent damaging is try to move parts of table from focus of laser.
    Will be enough 80 Wt chinese glass tube or 40 Wt SYNRAD. But keep in mind that cut area will be burned.
    Depends from laser manufacturer. Europe/Taiwan/USA - automatic, China - mostly manual
    Usually moving table on Z
    5axis machines do REAL 3D with high precision. Laser honestly speaking DO NOT produce 3D at all.
    For mould - no doubt - only router. There is no combined router/laser models on market and I think will not be as tasks for each technology is really different.
    Registered oneeye's Avatar
    Aug 2005
    Brazil
    Hi, i have been looking for a table with the co2 laser power, how thick it can cut and which speed. i need only aproximate, i need only to mdf or plywood and acrylic for ex.:
    co2 400w can cut mdf ......thick at ....in/seg
    acrylic...........................
    co2 200w can cut mdf ......thick at ....in/seg
    co2 100w can cut mdf ......thick at ....in/seg
    co2 80w can cut mdf ......thick at ....in/seg
    60W......
    40w........
    thank you
    Jul 2008
    Lithuania
    Do you want figures for glass tube or for RF tube? I will provide figures for RF tube later today when will be at home. But can't help you if you are looking for glass tube laser.
  7. #7
    Aug 2005
    Brazil
    Quote Originally Posted by Litografa View Post
    It is to glass tube.... well, if u find some reference about .....
    thank you 4 ya attention
  8. #8
    Jul 2008
    Lithuania
    Here is information from one of my customers. He have two chinese lasers with glass tubes - 60 and 30 Wt.
    Attached Files Attached Files
  9. #9
    May 2005
    India
    Well the picture is surely getting clearer so thanks a lot. Just a few more questions.
    1. How is the laser focussed as would it not burn a hole will trying to do so also do you just move ot up or down z axis for the smallest dot.
    2. How dp suto focus machines focus the laser?
    3. Why cant I replace the router in my cnc machine with a laser head what are the issues.
    4. do you determine the cutting speed by trial and error or is there a some system to do so.
    Best regards,
    fnp
  10. #10
    Jul 2008
    Lithuania
    1) In each laser you have lens which focus laser light. Each lens have FOCAL DISTANCE - usually in inches 1", 2", 4"
    Generally speaking FOCAL DISTANCE is distance between centre of lens and surface of material. If you have 2" lens, MAXIMUM POWER OF LASER will be on material's surface when distance between centre of lens and material's surface will be 2"
    Auto focus - once you input in laser memory type of your lens and laser automatically set distance from material.
    Manual focus - you just measure this distance with ruler and try to reach proper distance.
    2) Do not understand question
    3) Because they have different controllers, different software nad etc - it's practically impossible for you.
    4) For example we give to all our customer special manual which indicate APPROXIMATE speed/power settings for cutting/engraving of different materials. When we have start sales of lasers in 1998, this manual was half of page, now it is over 5 pages, because we collect different settings for different materials. So our customers start with settings from this table and after +\- depend from result
  11. #11
    May 2005
    India
    Thanks mate. If a laser cutter uses different software and controller then does it not operate on G-code. What does it operate on? What software is required? Can you name a few. Can the cut files be edited in a text editor or are they more complex.
    Regards fnp.
  12. #12
    Jul 2008
    Lithuania
    You ask me too much Command codes and etc it's not my area of responsibility - sorry, can't provide you information
LASER CUTTER BASICS
LASER CUTTER BASICS
