LASER CUTTER BASICS - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: LASER CUTTER BASICS
  1. #21
    Nov 2006
    FRANCE
    thank for your reply, i will ask my supplier to said the lenght focal, and I tell you the result
    laurent
  2. #22
    Sep 2006
    italy
    Annother possibility is, that the laser ray is out of the optical center from the focus lense. You should check it burning a paper above the focus lense utilizing a tiny laser pulse, the test button, if you machine have one.
  3. #23
    May 2005
    Saudi Arabia
    Hi Litografa
    I have a question. I have two leses of 2" and 4" focal lenghts. I would like to cut acrylic of 10-15 mm thick. What lense I should use it and at how may passes I have to repeat ?
    I would like to cut in 2-3 pass only. I have a few chinese machines with different watts and different sizes ( 40-60 watts.). But I would like to use in 1.0 M long 50 watt machine.
    Thanks in advance.
  4. #24
    Registered Litografa's Avatar
    Jul 2008
    Lithuania
    My suggestion is use 4" lens, cut in 3-4 passes and move material 1-2 mm higher than usual focus. I think you do not have autofocus, so set material to focus manually as usual BUT AFTER move table UP 1-2 mm.
    For the future
    1" lens for ultra fine engraving - very thin details, security elements for stamp making
    1,5" lens for fine engraving
    2" and 2,5" lens - universal - engraving and cutting up to 10 mm
    4" lens - for cutting
  5. #25
    May 2005
    Saudi Arabia
    Hi Litografa
    Thanks for your kind response and valuable information. How about speed and laser power for cutting crystals ?
    Regards.
  6. #26
    Jul 2008
    Lithuania
    Are you sure speaking about crystal? You can't cut crystals with laser.
  7. #27
    May 2005
    Saudi Arabia
    Sorry, not crystal but Acrylic 10-15 or 20 mm thick.
  8. #28
    Jul 2008
    Lithuania
    Have no idea for you as I sell GCC lasers with aluminium Synrad tube
    BUT
    1) You will not have problems with cutting 10 and possibly 15 mm, but for 20 mm quality of cut will not be perfect and you may be need do some finishing with flame polishing equipment
    2) Be carefull with acrylic. Cast is much better for cutting than extruded (but expensive ). There is now dark material from China LOOKS like black/dark blue acrylic but in reality contain PVC - can damage your equipment.
    3) Do not remove safety paper from acrylic before cutting as it will protect cutting area from residue.
    4) Be careful with cleaning and painting after cutting. Very often on EXTRUDED acrylic appear cracks after cleaning with some liquids and painting
  9. #29
    May 2005
    Saudi Arabia
    Hi Litografa
    Thanks for your kind and usefull information.
    Regards.
  10. #30
    May 2005
    Saudi Arabia
    Hi Litografa
    I did according to yor advise (moved little up 1-2mm) acrylic. It cuts fine. I have two little questions.
    1- If we cut 1.5 cm round, from the top it is fine but at the bottom it is not round but irregular. Upto 3/4 the finishing is fine but rest of them is rough. I am using 2" focal lenght Lense and having 3 pass of 1 cm thick acrylic.
    2- The sahpe of the final material is not straight from top to bottom. It is front side is more than forward and bottom also forward. It looks like little bend not like cylinderical.
    May be the last mirror above the lense is not correct or ??
    Regards.
    Muqtadir
  11. #31
    Jul 2008
    Lithuania
    Yes, as I told you before both problems will be during cutting of thick materials - more or less but will be. There is two ways to improve cutting quality:
    1) Use 4" lens
    2) Did special edge finishing with flame polishing equipment.
LASER CUTTER BASICS
LASER CUTTER BASICS
