LASER CUTTER BASICS - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 32
Thread: LASER CUTTER BASICS
  1. #13
    Nov 2006
    FRANCE
    hello,
    I am sorry, i need know if it is posible to make a laser line to 2 or 3 tenth width millimeter , with chinese laser co2!
  2. #14
    Registered Litografa's Avatar
    Jul 2008
    Lithuania
    From the Physics and Optics view - possible but everything depends from quality of laser
  3. #15
    Nov 2006
    FRANCE
    hi litografa,
    how make for optening a laser line extra fine, I have 2 laser machine the first is redsail 6090 with laser 60W, and one machine ruijie 1290 with laser tube 80W, with redsail I have a laser line of 2 tenth millimeters, but on the laser machine 1290 I have a laser line of 4,5 tenth millimeter, i do not understand because the light laser it is midle mirror!, the lenght focus is good, what to do!!
  4. #16
    Jul 2008
    Lithuania
    I think it's not possible have same line thickness on 60x90 cm table and on 120x90 cm table Also keep in mind that on 80 Wt tube laser dot ALWAYS will be bigger than on 60 Wt tube.
    As I understood on redsail 6090 laser tube is fixed, but on ruijie 1290 tube is moving with portal? Is it true?
  5. #17
    Nov 2006
    FRANCE
    Hi litografa,
    no, the laser tube on the laser machine ruijie is fixed, may be ,I have to change a lens focus...
  6. #18
    Jul 2008
    Lithuania
    First of all - do you have possibility install lens with smaller focus?
  7. #19
    Nov 2006
    FRANCE
    no, I have not an other focus lens, you know which lens focus i need for optening for small laser line?
  8. #20
    Jul 2008
    Lithuania
    What is focal lenght of your current lens? Ask you supplier - did they have different lenses? For example we sell 1", 1,5", 2", 4" lenses. Unfortunately our lenses are expensive and do not fit your laser.
    As you have 120x90 table I think you have 4" lens for cutting, but to have thin line you need 2" lens.
  9. #21
    Nov 2006
    FRANCE
    thank for your reply, i will ask my supplier to said the lenght focal, and I tell you the result
    laurent
  10. #22
    Sep 2006
    italy
    Annother possibility is, that the laser ray is out of the optical center from the focus lense. You should check it burning a paper above the focus lense utilizing a tiny laser pulse, the test button, if you machine have one.
  11. #23
    May 2005
    Saudi Arabia
    Hi Litografa
    I have a question. I have two leses of 2" and 4" focal lenghts. I would like to cut acrylic of 10-15 mm thick. What lense I should use it and at how may passes I have to repeat ?
    I would like to cut in 2-3 pass only. I have a few chinese machines with different watts and different sizes ( 40-60 watts.). But I would like to use in 1.0 M long 50 watt machine.
    Thanks in advance.
  12. #24
    Jul 2008
    Lithuania
    My suggestion is use 4" lens, cut in 3-4 passes and move material 1-2 mm higher than usual focus. I think you do not have autofocus, so set material to focus manually as usual BUT AFTER move table UP 1-2 mm.
    For the future
    1" lens for ultra fine engraving - very thin details, security elements for stamp making
    1,5" lens for fine engraving
    2" and 2,5" lens - universal - engraving and cutting up to 10 mm
    4" lens - for cutting
LASER CUTTER BASICS
LASER CUTTER BASICS
