you have problem with that machine??
hello
Is it that somebody has already bought a machine redsail X1201
lolo80
Hello
I have a REDSAIL laser X 1201 and this machine worked 2 times within 6 monthes. There is a main bug in the soft. REDSAIL sent me many patches but it is worth and worth, and now the machine is completely out of order
I am totaly upset with that. Have you found a solution with yours
Best regards
i almost buy from redsail. But i decide to buy from rabbit.
maybe you could change the software and the driver.
or contact redsail agent near your location. i heard they have agent on US, canada, UK, africa.
are you using easycut software on laptop?
if yes, maybe problem in your com port.
don't use USB to COM. better use PCMCIA to COM.
Thank's for your help, I am going to try that
I keep you informed
best regards
i already using laser cut 5.1
and that using usb support.
more convenience than com port.
