Easy enough to figure out... add an underscore to the end of each one until it fails to work. When something fails, you know it needs that file.
I have WKlaser LG900 and their USB stick was infected with a virus, apparently common in chinese USB sticks. The virus itself "auto.exe" was delerted by antivirus. There are several files on the stick I want to know. Which ones can I delete?
syscfg.ini
000.MOL
autorun.inf *(hidden file)
000.TXT
all created on 05 November 2007
Wklaser LG900 60W +rotary, Vinyl cutter and other stuff
Hi-TecDesigns.com -- Automotive Lighting Systems
Micheal,
I think (99% sure) that you can delete all of them. If you have a laser file you want to transfer to the laser with the stick, when you export the file from LaserCut to the USB stick, the software will add the necessary files that are needed for it to work.
New .ini, .MOL, and .txt files will be created for each job and transfered to the stick. I'm not sure how it would handle multiple jobs on it at one time, or if you can even do that.
I'm able to use the USB cable so I have only tried the stick one time to see if it worked, and it did. I deleted all the files on it before I exported a job to it, and the laser read them and loaded the job.
Hope that helps,
Skip
If its just a run of the mill memory stick and you have doubts about it?
Deep six it and get a new one, they're pretty cheap nowadays
Nuked the lot and used it. Machine just dont like files from USB, or I am not exporting them right.
Format the USB stick with a FAT16 and it will be fine. I mostly use the USB stick to transfer files to the laser
