Can someone help me with this case?, I have a 50w co2 laser 40x40cm, on my left side it cuts perfectly, (3mm mdf) on the right side it doesn't cut even if the power goes up. I've already aligned the mirrors and the bed, but that doesn't seem to be the problem.
Thank you Mathewn, I have found the problem, the laser was not completely aligned in the center of the head, I had already tested this before and it seemed to be correct, but I needed a millimeter more movement, it seemed that this would not affect it, but that was the problem.
