Laser marking white POM (Delrin/Polyoxymethylene/polyacetal)
Hi
We have a need to laser mark some enclosures molded in white POM. And our client wishes that it will be with a high contrast.
I know its possible to add some additives to the POM before molding - but right now he has 100 prototypes that we need to laser mark.
I have a 30W fiberlaser and a 30W CO2 laser marker.
With the CO2 laser I can make a fine and detailed engraving - but of course still white in white.
With the fiberlaser I get no result at all - no change in the surface.
I have seen a video on youtube with a fiberlaser and white POM:
but no mention of the settings. And maybe this POM is with additives?
All Laser marker sprays I can find are for metals - not for plastics.
Does anyone knows of any tricks to successfully mark (not engrave) in POM?
Re: Laser marking white POM (Delrin/Polyoxymethylene/polyacetal)
hello,
can you try for 30watt fiberlaser,
10% of power, 50khz frequency and speed around 2000mm/s and play with these, as for line intervals like 0.05
thank you.
