laser power output percent set
laser beam path ,
there are air pipe on laser head to blow smoking etc .
Hello,
I have 130W 500x700mm Chinese laser and laser head is getting hot after 10-15 minutes of cutting.I align laser beam on all 3 mirrors and laser beam hitting center of nozzle.I place tape around holeon head (where laser beam hitting mirror 3) and noticed something like reflection back from mirror 3 and reflection is hitting bottom of the hole.Any sugestion how to solve this because then head is hot laser cant cut well.Laser head have Mo mirror inside.
Thanks in advance
laser beam path ,
I would change the mirrors out if you can’t find where it’s hitting metal. Be careful working around a beam that’s deflecting somewhere.
