Newbie Lasers.................I have NO IDEA - HELP!!
Results 1 to 7 of 7
Thread: Lasers.................I have NO IDEA - HELP!!
    Member jrgrtx's Avatar
    Jun 2022
    Default Lasers.................I have NO IDEA - HELP!!
    So I have stumbled onto a "niche" business opportunity that involves cutting "fit check" templates out of thin acrylic and posterboard-type stiff paper (1/16" thick). I believe a laser would be the most accurate and effective but I know absolutely zero, zilch, nada, about lasers. I'd need something that could cut about 18" x 30" templates, 1/16" thick acrylic and posterboard-type thick paper. This would be repetitive cutting on a fairly large scale (20-40 cuts a day). Any help would surely be appreciated.
    Member haiqu's Avatar
    Mar 2011
    Default Re: Lasers.................I have NO IDEA - HELP!!
    1/16" acrylic and posterboard? Even the cheap K40 will do that.
    The old bloke in the shed.
    Jun 2022
    Again...................I know absolutely nothing at all about lasers. "K40" means the same to me as "ABC123".
    Jun 2022
    The "K40" i see on Amazon is only for 8x12 pieces. Again, this is for a minimum of 18" x 30" and for high volume.
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    Look for 6090 lasers 60x90 cm -> 23x35 inches
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Sep 2005
    Indonesia
    check atomstack x20 pro 130w laser ...
  7. #7
    Apr 2005
    Vanuatu
    atomstack x20 ic about 20W emited laser power, 130W electrical input.
    CO2 laserr tubes are declared on true laser power OUTPUT.
