I think the chance that someone is going to see this post and recognize that machine is low.
In the mean time I’d consider replacing/upgrading components. New DSP controllers aren’t that costly and you may need to replace other key components.
Like power supply, laser power supply, tube, motor drives depending on how unique they were in 2010.
How? You can test drive axis steppers with power and a signal into the drives. You can fire the tube with power and signals. You need to have a chiller.
