Hello everybody.
I'm trying to start my new CNC machine. It's just cheap CNC 1010 15W Laser Engraver Machine GRBL Control 2 Axis.
The first thing I decided to start was generating a g-code in the Inkscape and editing a bit.
(Header)
(Generated by gcodetools from Inkscape.)
(Using default header. To add your own header create file "header" in the output dir.)
(Header end.)
G21 (All units in mm)
(Start cutting path id: path2507)
(Change tool to Default tool)
G00 X185.832150 Y669.044650
M452
M4 S20
G02 X200.590954 Y678.973187 Z-3.500000 I54.775457 J-65.490133 F1000.0
G02 X217.142010 Y685.439080 Z-3.500000 I36.168652 J-68.166412
G02 X236.717388 Y688.065756 Z-3.500000 I20.651646 J-79.650603
G02 X256.379030 Y686.729910 Z-3.500000 I1.594496 J-121.894192
G02 X285.899015 Y679.221150 Z-3.500000 I-22.985522 J-152.147332
G02 X313.240750 Y665.687450 Z-3.500000 I-46.817602 J-128.969918
G02 X326.530040 Y655.422381 Z-3.500000 I-54.818868 J-84.703987
G02 X337.527190 Y642.782060 Z-3.500000 I-49.805570 J-54.435075
(Footer)
M5
G00 X0.0000 Y0.0000
M2
(Using default footer. To add your own footer create file "footer" in the output dir.)
(end)
Since I use the Linux operating system I installed the candle program. Because in my opinion it is the simplest. When I sent the code to the machine. The machine began to move as expected along the given trajectory, but after the command M3 C255 (M4 C255) the laser was turned on at a very low power (does not cut or engrave the material). I tried to disconnect the wire ttl after which the laser began to cut through the material. Maybe I need to add something in the candle setting or add something in the g-code? Since I'm a complete beginner in CNC, I don't even know where to start. Thanks in advance for any help.
