You can reverse stepper direction by reversing two wires.
Good Day.
I bought A11 Plus controller and connected it, Now the motors are running the opposite direction. All axis. i was replacing the 0401 controller. Whats the solution.
- Need Help!- Avid CNC Plug and Play NEMA 23 - Y axis motors running in opposite directions
- Machine decided to home x in the opposite direction
- Need Help!- How to Wire Stepper Motors Facing Each Other For Same Direction Running...
- Newbie- CNC problem, X goes in the opposite direction
- Need Help!- Mach3 is moving in the opposite direction
What software program do you use to run the cnc?.
There may be an option in the soft limits or axis pages to select 'axis reversed'.
Sometimes it's that simple.
Mactec54
Forgot about that way of doing it. Until I knew how opto's worked I was nervy about it as a total novice.
The way I understand it is: All it esentially does is swaps around the way the voltage is applied to direction.
For instance:
So if voltage isn't flowing in say active low it spins CCW, if voltage is flowing it spins CW.
Now switch to high:
Voltage not flowing is now CW, voltage flowing is now CCW.
Simple as that!!.
