If you have a small set of shapes to make and none are very large, then yes, a set of dies to be used with a press are probably worth investing in. But if there are lots of shapes or they're large, then a fiber laser would be your best bet. Unless you're doing massive quantities of these (and maybe even then) you'd probably be better off finding a shop doing custom laser cutting than trying to set it up yourself.
