Windows 10 once again has knocked my cerion laser offline. IN the past, a work around to install unsigned drivers was needed. This time, it is giving me an initiation error on the scanner card. Anyone having a similar problem or soulution?
Don't let a production machine to connect to interenet.
Simple as that.
Make no mistake between my personality and my attitude.
My personality is who I am. My attitude depends on who you are.
You can always go back if an update has caused a problem, it you don't want to get the updates then don't have the computer connected to the internet, it won't update if it is not connected and then if you do have to you can choose if you want it to down load or not it gives you that choice
So if you want to remove an up date go to settings
Settings
View Update History
Uninstall Updates
Mactec54
