Cleaning and maintenance of laser machines - airflow and plywood
Hi - We are laser cutting a lot of plywood. From time to time the machine has to be cleaned. The construction of the machine has had no input/help for this. It is always very time consuming. Therefore, I have three main questions:
- how do you clean the inside of your laser machine including the exhaust fan/blower?
- have you adapted the airflow? How - pro and cons?
- which is the best plywood 3mm for a laser machine to keep the pollution/dirtying as low as possible and who is producing/offering it? Where does ugears get their plywood from?
Thank you for taking part in this thread
