Building my own CNC Laser Cutter that cuts metal
Results 1 to 7 of 7
Thread: Building my own CNC Laser Cutter that cuts metal
    Member brainy19's Avatar
    Feb 2021
    Default Building my own CNC Laser Cutter that cuts metal
    Hi Everyone,
    I'm currently designing a CNC Laser cutter that can cut sheets of copper, bronze or brass, aluminum, and steel up to 2mm or 3mm thick. I have done some research online and it seems that YAG Lasers are the best choice but since I'm working on a small budget (I can maybe save $2K in a couple months), I would appreciate your guys' advice on how I can build my own laser cutter that can cut the metals I mentioned on a budget. Please keep in mind that I'm not worried about the CNC aspect (movement of the laser head on an X and Y axis) since I have already made a design for myself and have experience building such systems.
    If such a laser will inevitably be expensive, then please let me know what I would need to cut the metals I mentioned with high-quality (no jagged edges, etc).
    Feb 2021
    Default Re: Building my own CNC Laser Cutter that cuts metal
    Oh, and being able to cut Polycarbonate and FR4 (carbon fiber) as well.
    Member awerby's Avatar
    Apr 2004
    I'm pretty sure Polycarbonate is on the list of materials you can't (or at least shouldn't) cut with a laser due to poisonous fumes. FR4 would char on the edges. Metals are usually cut with fiber lasers. Most laser cutting machines cost in the range of $200k or more, so I'm doubting your budget will really stretch far enough, but please don't neglect the safety enclosure if you do build it.
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi Brain - I don't think your going to "cut it" at $2k budget. Heres a link to commercial machines will give you an idea of the power required...
    https://www.hsglaser.com/products/sh...EaAoXtEALw_wcB Peter
    Feb 2021
    Thanks you guys, looks like cutting metals won't be an option for me.
    Can I use a 40W CO2 laser to cut Polycarbonate and FR4 (carbon fiber) tho?
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    No.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  7. #7
    Aug 2017
    China
    now fiber power source is more popular with metal cutting .such as Raycus .
    Fiber 1000w laser metal cutting machine cutting brass
