Hello!
I want to make an co2 laser cutter in a budget of 350EUR (About 400$). I have already built an 30W (7.5W optical output) diode laser cutter, but it is too weak for my liking. I am thinking of ordering these components:
Maybe someone with a lot of free time could go trough these components and maybe spot if ive made a little error, for example the air is not enough or something like that?
I know there is the cheap k40 laser cutter, but im not happy with the max cutting size. I am planning to make atleast 500x500. The k40 if im not wrong is only 200x300.
You’ll need a controller. Stepper motors and drives. Belts and pulleys. A water chiller not just a water pump unless you plan on using a bucket of ice water. Not a suggestion btw.
Slides and frame to mount the slides on. Some way to rise/lower the platform. A platform to cut on. Sides and top/bottom to hold in the smoke. A way to exhaust the smoke(duct work and fan).
Other stuff like fasteners, limit switches , a computer the create designs, software, wiring, way to see into the cutting area. A place to put a machine about 1 m square.
The biggest challenge is to get everything aligned over 500mm square.
