It appears that the X axis is loosing steps. Is something causing resistance or additional weight on that axis? Hose dragging?
You can also check for and tighten pulleys on shafts. Make sure the belt isn’t riding on the pulley flange.
Check that the stepper motor isn’t getting very hot. Increase the amp setting on the stepper drive as a last resort. But that might increase the temperature
