Hi, i have strange problem in cuting. I own chinese 100w laser and some cuts makes me crazy...
When i cut same object, multiplied several times on working surface, in some of them dimension in X axis is bigger than it should be.
Sometimes smaller... And it happens only in x axis.
Do anyone have an idea what can be solution?
Im starting to be desperate...
First rule out mechanical issues by making sure the pulleys on the shafts are tight. Also watch the belts and insure they are tracking properly.
Do the larger parts always come from the same area of the machine?
Or it might not be, I had similar issues. I changed the belt, to a us made alternative no less, never got rid of the problem after a lot of time trouble shooting.
And I was isolating the rotation of the pulleys too, only testing on full sets of rotations (ie cut 1 rotation, skip one, cut one, etc).
The only problem that it might have been (I have just accepted the issue for years) is the beam hitting the lens in different spots and that was then magnified by the lens itself. That's harder to test for and I never did at the time.
I think I have solution for you here you can contact at info@heatsign.com you can also call at +86 150 6147 7073
Tel 86-510-85170177 and get end of your problems.
