Need Help! Wiring adapter for 220v 50w laser doesn’t make sense
Results 1 to 2 of 2
Thread: Wiring adapter for 220v 50w laser doesn’t make sense
    Jan 2014
    Default Wiring adapter for 220v 50w laser doesn’t make sense
    My 50w laser just arrived. I know that it is 220v. I look at the PC power supply and it says 220v AC. The power cord that came with the unit has a Jack Contact 3 pin connector on one end (P20K3Q) that plugs into the unit. The other end, I expected to have a large 220v connector, but instead it has normal looking 110v prongs. I assume I need to cut the end off and use a new male end but I have no idea which is the hot wire? I peeled the cord case back and it has a black, white, and green but I don’t know which is which? Am I over thinking this?
    Attached Thumbnails Attached Thumbnails Wiring adapter for 220v 50w laser doesn’t make sense-095b3717-cad7-4e50-9c71-8d99cff7beeb-jpg   Wiring adapter for 220v 50w laser doesn’t make sense-89f3a674-e601-4dd1-a3dd-736c45e8f5b9-jpg
    Jan 2008
    Default Re: Wiring adapter for 220v 50w laser doesn’t make sense
    White and black will be hot and green is ground 220 does not use a neutral
