Need Help! Adding a laser head to a CNC Router
Results 1 to 3 of 3
Thread: Adding a laser head to a CNC Router
    Jan 2017
    Member awerby's Avatar
    Apr 2004
    Default Re: Adding a laser head to a CNC Router
    Be careful about doing that. Cutting lasers can be extremely dangerous in ways that are hard to predict. There's a reason commercial laser cutters are totally enclosed with safety interlocks that turn the beam off when a hatch is opened. If it happens to shine on anything reflective, it can send a beam right into your eye, if it's not fully enclosed. So the enclosure is a must. Here's some advice on the subject from Hackaday: https://hackaday.com/2016/06/29/tami...-laser-cutter/
    Jan 2017
    Quote Originally Posted by awerby View Post
    My machine is actually already in a enclosure with acrylic windows so that’s a win
    I also have a vacuum that extracts dust and excess mist from my sprayer
    Good tip on fitting a cut-off switch of the door is opened tho.
