Laser Cutting Woes: Epilog Laser Suddenly Won't Cut as Deep
Results 1 to 4 of 4
Thread: Laser Cutting Woes: Epilog Laser Suddenly Won't Cut as Deep
    Default Laser Cutting Woes: Epilog Laser Suddenly Won't Cut as Deep
    Howdy, All.
    I have a 30-watt Epilog Zing CO-2 laser that I love. This morning I cut some Acrylic around 1/4" (6 mm) thick. It cut beautifully.
    About three hours later, I cut the same sheet of Acrylic with the Epilog and it suddenly won't cut through. I tried it several times. Won't cut through.
    I'm new to laser cutting, but my first thought was to clean all the lenses and mirrors. Would that be the best place to start, or should I be looking elsewhere? Again, I'm a novice.
    BTW, here are the settings I used:
    SPEED: 50%
    POWER: 100%
    FREQ: Tried both 2500 and 5000
    Thanks in advance for any suggestions.
    cl
    Apr 2004
    Oakland CA USA
    Default Re: Laser Cutting Woes: Epilog Laser Suddenly Won't Cut as Deep
    Have you asked Epilog's tech support?
    Andrew Werby
    https://computersculpture.com/
    Quote Originally Posted by awerby View Post
    I will next week if it persists. I was actually cutting the Acrylic to use as a jig to hold another material I'm cutting. Luckily, the other material isn't nearly as thick and is cutting just fine, so at this point it's more of a work-holding issue. But by next week I'll be back to cutting Acrylic, so I'll give them a call if still encountering this.
    Thank You,
    cl
    Nov 2010
    united states
    always first place to start is cleaning lenses, and mirrors
