Newbie 80W not cutting through 1/4ply?
Results 1 to 3 of 3
Thread: 80W not cutting through 1/4ply?
    Member Jessicacooper94's Avatar
    Jul 2020
    Default 80W not cutting through 1/4ply?
    I just got this machine a week ago, I have aligned all the mirrors and done a ramp test. I’ve tried running it all the way up to 85 power/ 5 speed and it still isn’t cutting through 1/4inch Baltic birch. Any suggestions would be appreciated
    80W from G Weike (LC1390N)
    Member oneeye's Avatar
    Aug 2005
    Brazil
    Default Re: 80W not cutting through 1/4ply?
    80W can cut 1/4" easly , around 10mm/s. Are you sure it is perfecly aligned? Are you working with correct focus?
    Jan 2009
    Quote Originally Posted by Jessicacooper94 View Post
    How is it when cutting other products?
    If your laser is cutting 1/4 inch acrylic or solid wood easily, the machine is probably working fine.
    Plywoods can be tough to cut.
    Some of the glues used have mineral fillers in them and you can't laser rocks.
    Baltic birch can be a problem in that even 1/4 inch has multiple layers of glue.
    I even have issues with certain multi layer plywoods when using a CNC router.
    Sparks fly off the bit which is then sucked into the vacuum system.
    If other materials cut without issue, its the glue, not your machine.
