Software problem with dual head laser cutter, can't cut wide items.
Results 1 to 2 of 2
Thread: Software problem with dual head laser cutter, can't cut wide items.
    Member timmbbo's Avatar
    Jun 2020
    Default Software problem with dual head laser cutter, can't cut wide items.
    I'm having problems programming a dual head laser cutter I recently acquired. The heads are duplicating the cut, instead of mirroring the cut.
    First, both heads are the same gantry, so the Y motion is identical. I have a Guanghou Puhan DSP controller. The bed is 1300mm wide. Each head can only reach half the bed. The left head covers the left 650mm, and the right head covers the right 650mm. The problem comes when I want to cut a wide item. I need the left and right heads to cut a mirror image of each other. Instead, the right and left head copy each other. I've gone through all of the software and panel settings, and no luck, unless there's some magic combination I don't know about.
    I'm aware that I could cut the left side with just the left head, and then cut just the right side with just the right head. However, that seems pretty stupid. The reason why I got a dual head laser is to cut twice as fast, not twice as slow.
    Any thoughts on this? Thanks for your help.
    Attached Thumbnails Attached Thumbnails Software problem with dual head laser cutter, can't cut wide items.-foo16-jpg   Software problem with dual head laser cutter, can't cut wide items.-foo17-jpg   Software problem with dual head laser cutter, can't cut wide items.-20200624_153124_1593044237920_resized-jpg   Software problem with dual head laser cutter, can't cut wide items.-20200624_150028_1593044248539_resized-jpg
    Default Re: Software problem with dual head laser cutter, can't cut wide items.
    Hello,
    If you need any help or advise regarding your Co2 laser machines we would be more than happy to help. We offer Co2 lasers machine and parts sales as well as offering maintenance agreements, tech support, parts installation with warranty, maintenance agreements and much more to ensure your machines get back up and running as soon as possible.
    Please do visit our website at Laser Cutter | Laser Engraver | Laser Machine Parts & Accessories | CO2 Laser Machines | CO2 Laser Repairs | CO2 Laser Engineer or email info@focusedlasersystems.com for more information.
    Kind regards,
    Jake Osman
    Focused Laser Systems Ltd
