Rudia Controller resets settings when restarted
Results 1 to 2 of 2
Thread: Rudia Controller resets settings when restarted
    Member noney's Avatar
    Oct 2019
    Default Rudia Controller resets settings when restarted
    Hi, I had an issue with my machine where the rails were colliding and grinding until I pressed an arrow key. The machine home wax set as 10,000, 10,000 unsure how it got to that, it should have been 0,0. I reset the axis and the limit sensor for the Y automatically grips and stood the collision and grinding. The X however I have to manually make trip using a metal object as the laser head is approaching the sensor.
    So now, issue is solved and no more grinding... that is, of course, until I turn my machine off. Once I turn it back on, it's back to 10,000mm 10,000mm and the grinding starts again. I have to do above process again. Any ideas?
    Jan 2008
    Default Re: Rudia Controller resets settings when restarted
    Try doing this just move you head to where you want 0x 0y to be draw a small box set the laser to 0% then hit start. It should act like it cut and when it is done it should be at The 0x 0y that you set. shut down and restart and see if that solved your problem.
