Compensation function locked; stima Engineering compact tower software, simatic panel
we are dealing with an issue due to the natural elongation of the metal wires that support the elevator system on the tower and have to run the compensation function.
this panel is connected to a Prima Tower and a Prima Laser.
we have been able to get into it before with some of the factory default passwords listed below, however we have replaced our Siemens Simatic Panel since then, and the existing default factory passwords we had as well as those found online do not work at all to open the option.
I have personally tried all of these with all caps, all lowercase, with the first letter capitalized and even the aforementioned options with the full "Administrator" spelled out with each of these password to no luck.
admin
100
admin
1111
admin
17121962
Edit: i do not know why the picture is upside down, I have tried re-uploading it and manually rotating it 180 degrees to no avail...
Re: Compensation function locked; stima Engineering compact tower software, simatic p
we cannot even run the device in a semi auto mode with this blue box we had assembled with 5 A and B codes that do semi auto tasks with both machines due to the slack in the cable it isnt able to compensate for.
