Need Help! Laser not engraving clear images anymore
Results 1 to 2 of 2
Thread: Laser not engraving clear images anymore
    kpncfl12's Avatar
    Apr 2020
    Default Laser not engraving clear images anymore
    Engraver was working fine and out of nowhere, started engraving the images "blurry?" Instead of getting a crisp image engraved, it almost just leaves behind a fuzzy burned version of the image. See picture attached of an image engraved before when it was working correctly vs now. I tried cleaning out the water lines that cool the laser, replaced the laser tube, cleaned and realigned the mirrors... to no avail. Any ideas on how to fix this would be greatly appreciated! No settings on the software have been changed. This is the 3rd time this has happened but the previous 2 times it somehow corrected itself and started working properly a couple of days later.
    Engraver description: 40W Co2 Laser Engraving Cutting Machine, 12 x 8 Inches K40 Desktop DIY Wood Laser Engraver Cutter
    Attached Thumbnails Attached Thumbnails Laser not engraving clear images anymore-screen-shot-2020-04-23-10-56-a
    Jan 2008
    Default Re: Laser not engraving clear images anymore
    Have you cleaned your lens and mirrors. Also is the lens in the correct way
