General Laser Question , multiple talks job run
Results 1 to 8 of 8
Thread: General Laser Question , multiple talks job run
    Member Mudu3000's Avatar
    Mar 2020
    Default General Laser Question , multiple talks job run
    Hi l am a newbie to the laser world having owned one for just over 4 weeks. I am trying to figure out how I can, engrave at different power, speed and finally cut a material design in a single run?
    By this I mean using corel draw to setup the sequence of activities and executing as one job.
    Example:
    1. Engrave a star at 20% power , speed 100 mm/s
    2. Engrave a star at 50% power, speed 150 mm/s
    3. Engrave a star at 75% power, speed 200 mm/s
    4. Finally cut out rectangle, power 30%, speed 10 mm/s
    I could be wrong but my research indicates that I cant do the above in one run! I have to manually do each step.
    Can someone help clarify this please?
    Jan 2008
    Default Re: General Laser Question , multiple talks job run
    You have to use colors and set each one to what power you want and scan or cut
    Mar 2020
    So it is possible
    Are you aware of any videos or tutorials that will help me get my head round this?
    Jan 2008
    You just have to assign a color to each thing and adjust your settings to do what you want.
    Mar 2020
    Quote Originally Posted by fixtureman1 View Post
    I have figurer out how to run two tasks, engrave and cut, but how do you set the power for each task from the software? My laser machine has a digital display that I have to adjust for the power in %.
    Jan 2008
    What controller do you have
  7. #7
    Mar 2020
    Controller: Nano M2;
  8. #8
    Mar 2020
    Default How do I enable the power feature in coral draw laser?
    Hi folks, wondering how I can control thr power of my laser machine from the coral laser software package. See image attached, as you can see the feature seems to be disabled.
    Attached Thumbnails Attached Thumbnails General Laser Question , multiple talks job run-img-20200501-wa0000-jpg
