I don’t think a laser is a good choice for this material. First off the size makes the machine design custom because you would have to carry the tube with the carriage. So diode solves that but will it cut 1mm? Then you always have to deal with smoke which would be difficult to capture. Then will the air blowing mess up the canvas? Will burnt material contaminate either surfaces? How fast will it cut? Testing could help answer some of this.
I wonder if you should considered a cnc knife or cutting wheel?
