30w fiber laser marking outside of contour
Results 1 to 6 of 6
Thread: 30w fiber laser marking outside of contour
    Jan 2008
    united state
    Default 30w fiber laser marking outside of contour
    Have not had this laser long. 30w split unit from ebay.
    I'm having a hell of a time getting clean marks once hatched.
    if I just follow the contour, they look great.
    Looking at text under a magnifier, I can see that the laser has fired outside of the contour.
    if I use the "ring like hatch", its fine. but any other hatch leaves marks as if follows the hatch pattern...
    attached some pictures, you can see the white dots outside the pattern that follow along with hatch.
    what am I doing wrong here?
    thanks in advance
    landy
    Attached Thumbnails Attached Thumbnails 30w fiber laser marking outside of contour-20200126_234819-jpg   30w fiber laser marking outside of contour-20200126_234839-jpg
    Member keyencelaser's Avatar
    Dec 2019
    Default Re: 30w fiber laser marking outside of contour
    Quote Originally Posted by landy View Post
    thanks in advance
    landy
    Nothing's wrong, HAZ - heat affected zone, wrong laser to wrong material, if this is metal, too much power on the martial,
    in order to lower the problem, either lower power, but it still will be there, so change it to cold marking, other green or uv, or piko green or piko uv.
    Kind Regards.
    Member oneeye's Avatar
    Aug 2005
    Brazil
    landy
    What material r u trying to marking?
    Member WIESELE's Avatar
    Jan 2020
    Try changing some of setting on the actual text.
    Our laser software (right click on the word ) Step, speed, power % overlap
    good luck
    Jan 2008
    united state
    First off,
    thank you all for the replies.
    The material is mild steel, piece of square tubing to be exact. just something I had around I could test on.
    I change the hatch to 1mm to better illustrate.
    To me it looks like the laser is either firing outside the contour, and or turning off to late.
    Basically I'm stuck with using the ring hatch, as it doesn't do this.
    thanks again.
    Attached Thumbnails Attached Thumbnails 30w fiber laser marking outside of contour-20200127_191714-jpg   30w fiber laser marking outside of contour-20200127_192036-jpg   30w fiber laser marking outside of contour-20200127_192018-jpg
    Dec 2019
    First off,
    thanks again.
    this is your answer
    Kind Regards.
