- Cutting 3mm cast acrylic with a 30W Chinese laser?
Hey,
I am looking to cut 3mm acrylic (for hobby purposes), and then engraving it with text.
I looked at buying a K40 laser from China but I have concerns that I won't be able to clear it with my country's customs due to the laser component.
I have an opportunity to locally purchase a used 30W Chinese 3020 laser cutter, which fits my working area requirements.
Will I be able to properly cut 3mm acrylic with 30W of power? Will I have to run my laser at high power therefore causing it to wear more quickly?
What might be important to note is that as the laser will be used for a hobby, it won't be used very frequently.
Thanks!
- You may not post replies
- You may not edit your posts
Forum Rules
