K40 Laser not cutting 3mm MDF
Results 1 to 2 of 2
Thread: K40 Laser not cutting 3mm MDF
    Member noney's Avatar
    Oct 2019
    Default K40 Laser not cutting 3mm MDF
    Hi, I've got a K40 laser that is set up with air assist. I'm struggling to cut 3mm MDF with a single or even a double pass even though I've got the machine on full power on 5mm.
    Not entirely sure what the issue is, I've tried Googling and looking for answers but can't really find anything. I've read that these machines can cut 6mm MDF with 2 passes therefore would have assumed cutting 3mm MDF should be no problem at all, especially running at full power.
    Any ideas?
    Member TokinSpokane's Avatar
    Mar 2019
    Default Re: K40 Laser not cutting 3mm MDF
    Run at 65% power.
    Sent from my SM-G935F using Tapatalk
    TokinSpokane
    Custom Crafts
