Co2 Laser 6 KW with Stainless Steel 20 mm - Bystronic
Hello Colleagues
I have a problem when cutting 20 mm Stainless Steel on a C02 Laser of 6kw.
The cut itself i am OK ( when it cuts ) but when i do the initial piercing i have a build up of material that makes impossible to cut. The laser just stops cutting like 90% of the time.
Laser Type - Bystronic. Power 6 kw.
Please if you can to offer some help. It will be appreciated .
