- fiber laser engraver newbee
I an a gunsmith in New Mexico and am researching American made laser engravers and have narrowed the search to two companies with 20 Watt galvo lasers. LaserStar in California and TYKMA Electrox sold by Inovative cutting Systems in AZ. Both are in the budget range of under 30K. Is 30 Watt that much faster and deeper?
Re: fiber laser engraver newbee
Gunsmith. Going to deep engrave scrollwork? Or just do deep text such as NFA info?
If going to do complicated work on full slide, I’d spring for a 30 watt. I’ve a 20 and as it does most of what I want, a 30 makes it go several times faster.
Either company is good btw, I’ve a cheap Chinese
- You may not post replies
- You may not edit your posts
Forum Rules
