Is it alarming because of low or no water flow or because it not cooling, which means the compressor is not running. This is the refrigerated model…. correct? Turn off, grab a 5 gal clean bucket and pull a hose off the back of the laser, the OUT one if they are marked. Water should run out the machine connection, and when you turn the pump back on it should pump water out of the machine, if not thats your problem.put that hose back on and try to see if the IN hose is pumping. I have had algae plug up the laser tube hoses and cut off the water flow.
