RD6442 settings configuration on K40 laser machine
Results 1 to 2 of 2
Thread: RD6442 settings configuration on K40 laser machine
    Member NeODarK's Avatar
    Aug 2019
    Default RD6442 settings configuration on K40 laser machine
    Hi, I have installed an RD6442 on my K40 laser.... When I try to cut at low speed... 5-6 mm/s the Y axis goes little fast as X axis... then the X cut is done but Y cut not because speed is a little more... How I can fix it in configuration?
    Another question...
    I have this laser power supply
    https://lh3.googleusercontent.com/1-...20-h1080-rw-no
    Is anyway to control the laser with RD6442 by PWM?
    Thanks!!
    Member Mecanix's Avatar
    Aug 2019
    Default Re: RD6442 settings configuration on K40 laser machine
    Interesting problem.
    I don't have a K40 but would still be interested to know what the User or Service/Troubleshooting Manuals says relevant to the adjustments of the machine/software.
    I assume at this stage you've also contacted the seller/manufacturer and asked for support, what was their answer?
    Lastly what have you done so far to diagnose the problem? Asking because we need to know where you are in your troubleshooting process, so to avoid blindly proposing steps you may have already tried.
    Let's hope for the best
